Fly 45 ise SB
- Алексей
- ФИО: Шитоев Алексей Васильевич
Fly 45 ise SB
Интересует инструкции по настройке для вертолёта. Если не ошибаюсь нужен прогроматор,может у кого есть сей девайс и опыт?
Всем спасибо!
Re: Fly 45 ise SB
Поразвернутей вопрос задай, а то я голову уже сломал, про что тут написано.
Есть подозрение, что про регулятор.
Дай ссылку где брал, например
- Алексей
Re: Fly 45 ise SB
Здравствуй Саша. Так точно,регуль вертолёта, как можно проверить настройки ,например писки, регуля при подключении АКБ.
Всем спасибо!
Re: Fly 45 ise SB
www.geocities.jp/kkshrimp/guide/FLY_pro_ESC.pdf
Взято оттуда:
Option paremeter assistant by transmitter
The transmitter can set only one parameter of ESC at a time. If you want to set several parameters, please repeat the
following procedures:
Plug the JR connector into throttle control channel of receiver.
Switch “on” the transmitter and move the stick of throttle to the highest position.
Connect the main power pack to ESC (pay attention to the polarity).
Wait for 5 seconds, you will hear 4 beeps, that means it entered the programming mode.
And then you will hear 5 “single beep”, then 5 “double beep”, then 5 “triple beep”, then 5 “quartet beeps” and then 5
“penta groups”. And these sounds will circulate continuously.
Each group of 5 sounds stands for a different parameter of ESC respectively.
You can put the stick of throttle to the lowest position during one group of 5 sounds, then the corresponding mode is
saved.
Hear 1 “♪”(Brake-Medium) or "♪♪" (Brake-Off) , then you can exit the setting mode after saving the mode.
When the mode is saved, you can disconnect the ESC to the battery pack.
Brake: Hear the first “♪♪♪♪” in the above circulation, put the throttle stick to the lowest position, the braking mode is
changed from Brake-off into Brake-Medium. If you want to change back, please repeat the above procedures, and
vice versa.
Battery type: When you hear 5 groups “♪” or “♪♪” or “♪♪♪”, move the stick of throttle to the lowest position.
1 “beep”: Li-XX battery
2 “beep”: NiCd, NiMH battery
3 “beep”: LiFe battery
Timing: Hear 5 groups “♪♪♪♪”or “♪♪♪♪♪” , move the stick of throttle to the lowest position.
4 “beep”: Automatically change the timing of motor(recommended for all types of motors)
5 “beep”: Timing-High(recommended for 10 (or more) poles motors and outrunner motors)
Note: When the timing mode of motor is saved, please adjust the motor on the ground before the flight.
Взято оттуда:
saved.
vice versa.
Re: Fly 45 ise SB
Почитай мануал на русском для T-Rex450. Методика и алгоритм те же.
Все сводиться к прослушиванию комбинации звуков и выбора перемещением стика газа.
Совет: на листочке нарисуй нужную комбинацию и куда двигать стик.
Прослушать просто.
Включил передатчик, стик газа в максимум.
Включил питания модели.
Пропоет трель входа в программирование, стик вниз и начнет издавать писки.
Смотришь, что нарисовано в мануале согласно пискам и делаешь выводы.
ТОЛЬКО ПЕРЕД НАЧАЛОМ НЕ ЗАБУДЬ СНЯТЬ ПИНЬОН ИЛИ ОТВЕСТИ ЕГО ОТ ВЕДОМОЙ ШЕСТЕРНИ!!!¡
Прослушать просто.
Re: Fly 45 ise SB
Судя по фото, рама как на T-Rex450PRO
Две половинки на винтах М3.
Хорошая, живучая.
Сори за оффтоп)))
Хорошая, живучая.
Сори за оффтоп)))
- Алексей
Re: Fly 45 ise SB
Николай спасибо, твои советы всегда выручают ,про запись действий и трелей ,по 35 алигну делал 2 года назад . может помнишь. Спасибо. Просто на дизайре нет темы, а с рук ,да хрен знает как настроен. + ещё вопрос,если движок на 6 банок ,на 3 поднять врядли ?
Всем спасибо!
Re: Fly 45 ise SB
6 банок против 3-х - это просто оборотов будет в 2 раза меньше. Летать не будет.
Re: Fly 45 ise SB
А как ты определил, что 6S?
Буковки на двигле есть?
Если да, то понятно.
- Алексей
Re: Fly 45 ise SB
Двигло перемотаное со слов бывшего владельца,на 3х банках не летит,пробывал,надо менять и регуль перенастраивать.
Всем спасибо!
